Strange timing issue after belt replacement
I'm having some strange issues with my 1991 camry. I just got done with a timing belt job on my 3sfe, all new seals, etc. I read through all the write ups here on the forums, lots of great info, and everything was going just fine. After I finished I started my car and it idles and revs fine. Before I took it for a test drive I checked the ignition timing and it's pretty far advanced, off the scale actually. I would guess its around the 17-19 mark, if there was one. The hole on the cam pulley is lined up perfectly on its mark when the notch on the crank pulley is lined up with the 0 degree mark on the cover. I decided to pull the cap on the rotor to see where it was, and its smack dab right on the number 4 plug. So now my question is, how is my car running? The rotor should be pointed at the number one wire, correct? I have never pulled the rotor before, and as far as I can tell the car is running like she has for the past year I've had it. So any ideas? Its hard for me to believe the timing has been this far off for so long, but its possible. Thanks for the help!
Greg Boser
