91 Camry Tailights & Head Lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2009, 01:30 AM   #1 (permalink)
View Jeoy Gunz`'s Photo Gallery
2nd Generation 91 Camry Tailights & Head Lights
Hey guys i was wondering does anyone know if its possible to get a different glass for the headlights because i have HIDs in mine but the glass isnt totally clear which dosent make the lights as bright as they should be. Also iv seen other camrys with different tailights as mine. I was wondering if the fight exactly to mine i have the tailights that are not flat. Thanxs a lot guys.
http://www.cardomain.com/ride/3206957
Jeoy Gunz` is offline   Reply With Quote
Old 03-16-2009, 01:57 AM   #2 (permalink)
View nuron's Photo Gallery
I don't think there's different glass besides maybe the Australian ones but they're very fluted as well. Different years had different tail lights--they should all be interchangeable.
nuron is offline   Reply With Quote
Old 03-16-2009, 05:12 AM   #3 (permalink)
Toyota. Possibilities.
PaulyJay's Avatar
View PaulyJay's Photo Gallery
are you wanting to replace the lens or the whole unit? if it's the glass, then why not remove the lens, clean it with a mixture of 1 part amonia to 20 parts HOT water and newspaper to scrub it. most "clouding" on glass is either scratching, or build up. this cleaning will remove the build up. beware the fumes from the amonia, it can be noxious, and toxic. to undo the clips use a screw driver, and you may want to replace the rubber afterwards. your reflector may need looking at too.
Australian 1990 Camry CS Wagon 3S-FE, S51 5Spd Man (RIP)
Australian 1990 Corolla SECA Liftback 4A-F, 5Spd Man (RIP)
Australian 1990 Corolla SECA Liftback 4A-GZE, 5Spd Man, AWD (currently in build)
PaulyJay is offline   Reply With Quote
Old 03-16-2009, 09:25 AM   #4 (permalink)
My headlight lens isnt dirty its the way they r mad its like a prizm its not perfectly clear like a window. I was wondering if that can be changed.
Old 03-16-2009, 11:39 AM   #5 (permalink)
bkbajan's Avatar
View bkbajan's Photo Gallery
i believe you are talkin about the flutes (lines) on the headlight...sure,u cud remove the fluting but it wudnt make sense...ur light output wud be all messed up...
about he tail lights..the two different types will fit regardless..i like the 91 tail lights better,i need a pair for my 88
bkbajan is offline   Reply With Quote
Old 03-16-2009, 01:00 PM   #6 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
no there isn't anything you can do about the headlights it's made out of glass so unless you want to take it apart then spend days sanding down the glass to make it smooth... tail lights nothing you can do really unless you want to import some..
here's a set i got from japan.. it's a lighter red and the turns aren't as ugly
Old 03-16-2009, 03:00 PM   #7 (permalink)
View Wangan's Photo Gallery
thank you atobe thank you. yet another part I need to buy. thanks so very much. thank you.
what year jdm camry is that off of?
http://i4.photobucket.com/albums/y11...3385Medium.jpg
Here's my camry ^
Current: B+G Springs, KYB GR2 Struts, Erebuni Bodykit(uninstalled), 3SGTE/E52 swap, Crane HI-6S Ignition Box, Crane Timing Retard Controller.
Plans: Here
Wangan is offline   Reply With Quote
