89 toyota 2.0 4cyl no atart? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-03-2009, 08:15 PM   #1 (permalink)
View booshwa73's Photo Gallery
2nd Generation 89 toyota 2.0 4cyl no atart?
Driving at 60mph check engine light came on car died. No spark checked rotor button with cap off and it is turning. Jumped the e1 and the te1 terminals on diagnostic plug and its giving me a code of 14-(ignition signal) What does code 14 mean? New ignition coil in dist. 6 months ago. 168,000 miles 4cyl 2.0. Went to junk yard p/u a different Ignitor changed no luck. I am mechanically inclined I'm just stuck now and don't know what to check. If anyone nows what code 14 means and what I should start checking it would be a great help Thank You.
booshwa73 is offline   Reply With Quote
Old 04-03-2009, 09:52 PM   #2 (permalink)
View toyomoho's Photo Gallery
Ignition Signal-No signal from igniter to ECU
IGT, IGF or B+
Igniter or circuit
Ignition coil or circuit
ECU
The igniter sends the IGT and IGF signals to ECU.
Have you checked for ign spark, wiring problems and blown AM2 fuse?
The AutoZone website has a good self help section for checking the ignition
Old 04-04-2009, 04:08 PM   #3 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Unplug connector at igniter; check for the +12 v with ignition on at black wire with orange strip
make sure the housing of replacement igniter is attached to the ground before testing.
Also turning ignition on with igniter unplugged causes 14 code.
Finally make sure that terminals at igniter connectors are not pushed back into their cavities too far.
Doctor J is offline   Reply With Quote
Old 04-11-2009, 02:10 AM   #4 (permalink)
What is the IGT,IGF,or B+
IGT, IGF or B+
Igniter or circuit
ECU
igt, igf and b+ what are those ?
Old 04-11-2009, 02:24 AM   #5 (permalink)
Hey thanks Doctor J anything else i might try
I need all the help I can get. if you dont care me to be a burden
