Originally Posted by himajin123
You can remove all of it and have no adverse affects on the engine/ performance. It's only purpose is to reburn exhaust gasses, the ecu doesn't even "see it". None of the JDM 3SFE engines have the EGR systems.
Burn exhaust valves? Not a chance..
The EGR system lowers exhaust gas temps, helping the motor run cooler and lowers pumping loses, allowing the motor to get better mileage in some cases. If the ECU is tuned to work with the EGR system, it should run better with it (the JDM ECUs are tuned to run without it - different timing and fuel). If it is still working, leave it in place.
That said, I have run with and without the EGR system with no major effects either way. I ran without it to get rid of possible vacuum leaks when I had my turbo 3s-fe, but have left it in place otherwise.
-Charlie
PS. Yes, it would contribute to burned valves. You can think/say otherwise, but I would trust the guy that has seen thousands of these cars (Doctor J)... or even me, who has run well over 100k miles on three different 3s-fe in various states of modification (stock, IHE, turboed, etc.).
