1st & 2nd Generation (1983–1986 & 1987-1991)Toyota Camry Discussion for years: 1983-1986 & 1987-1991.
The O/D Off Light on my 1990 Camry flashes consistently every time I engage overdrive. I have approximately 117k, and the car drives as well now as it did when I bought it 12 years ago. The light started flashing a few months ago but there hasn't been any change in how the transmission behaves.
I disconnected the battery for about 30 minutes, then reconnected it. For the next two days, the "O/D Off" light did NOT flash when I engaged overdrive. On the third day, the "O/D Off" light began to flash as soon as I moved the car 15 feet with the overdrive button engaged. The light doesn't flash when the car is in reverse, or when the O/D button is disengaged.
Does anyone know what the flashing O/D Off light indicates?
Any help you can provide would be greatly appreciated!
Thanks in advance,
Steve
Seattle
1990 Camry LE/V6 AT 117k
Hi everyone... Nice to join here..I actually have the same problem with yeravgjoe. Anyone of you have any idea what is going on? My O/D light also keep flashing once I engage the overdrive..FYI, I am drving a 96 Camry with 5SFE engine on it.. Thank you
Thanks for the reply. However, this is not an engine light blinking. It is the O/D light blinking and it blink consistenly.. Without stop in between any intervals. Anyone of you guys have any idea about this? Please help... Thank you..
I really need help over here. I have 2 situations here.
1- My ABS blink and i check the code exactly like alflash website.
2 codes apprear. code 31 and code 36. Please let me know what is going wrong with my ABS system.
2- My O/D light is flashing these few days. I sent it to my mechanic and he said it is the loose and spoil switch( The OD switch) Besides the OD switch, is there any sensor around? How to confirm if it is the OD switch problem? Is there any code apprear if it is my OD switch. Anyone have any diagnostic code references, ie..code 81 is for OD switch, etc, etc...
For your information, i am using the A140/03E Auto gearbox..
Hello,
Dear Sir,
1. Quotes.
a) ABS. DTC DEFINITIONS (BOSCH):
...Code 31. Malfunction of right front wheel speed sensor signal. Check speed sensor, sensor rotor, wiring harness and connector.
...Code 36. Open in left front wheel speed sensor circuit. Check speed sensor, sensor rotor, wiring harness and connector.
b) DTC DEFINITIONS (NIPPONDENSO):
...Code 36. Open in right front or left rear wheel speed sensor circuit.
c) IMO: these codes is "history codes"...
Need clearing DTCs (by removing ECU-B fuse, but other memory systems will be canceled or by "Turn ignition on. Remove short pin from DLC1. Connect jumper wire between terminals Tc and E1 of DLC1 or DLC2. With vehicle stopped, press brake pedal 8 or more times within 3 seconds.
DTCs will be erased. Verify ABS light goes out after 3 seconds..." and verify ABS light flashes normal DTC (ABS light flashes 2 times per second).
Under normal driving read codes again.
2. A/T A140E has't code 81*... and it has't code for malfunction O/D switch**...
**OVERDRIVE (OD) SWITCH. Disconnect electrical connector from OD switch, located on shift lever. Using ohmmeter, ensure continuity exists between terminals No. 1 and 3 on Camry with switch released (OFF position). Ensure no continuity exists with switch depressed (ON position). Replace switch if defective.
Let me know and I will send to you description for Diagnostic (from Mitchell On-Demand).
HTH,
J2008: Beginning 2002, manufacturers shall make available at a fair and reasonable price,all 2002 and newer model year vehicle emission-related diagnosis and repair information provided to the manufacturer’s franchised dealers.Within 30 days of its availability to franchised dealers.
I just get my tranny code. This O/D light blink a few codes.
The codes are 42,62,63 and 64. When the car is idling, the OD light wont blink. If you rev the car while it is not moving, the OD light will blink again. After that, if you drive , for a while, the blink will gone.
Besides that, If I drive downhill and the gear is at 4th, when i press OD off, it will goes to 3rd gear but when I pull 2nd gear, the tranny wont goes into 2nd gear unless i accelerate a bit on the throttle.
Finally I fixed the O/D problem. Previously, the OD codes blink 42,62,63 and 64. After I change one of the solenoid.( should be 2nd gear solenoid) all the 62,63 and 64 codes are gone. Now only have code 42.
I know this is the vehicle speed sensor, Anyone know where is this sensor located? I am driving a 5SFE with A140 auto tranny.
Originally posted by clutterking There are 4 speed sensors, one at each wheel
I think the 4 speed sensor you mention is ABS speed sensor...SHould be only one vehicle speed sensor but I do not know how it looks like..Thanks for your reply ..
