problem replacing front sway bar bushings
First thanks to the many posters here in the Gen 1 & 2 forums. I've solved a lot of the issues with my '91 Camry, with many more to go.
Here's today's problem though, while changing the front sway bar bushings (sway bar to frame bracket, not LCA's) I have one bolt that is apparently stripped as it turns but doesn't thread out. This is where the sway bar bracket bolts on to the corner frame piece (for lack of a better word). Seems like they were stupid enough to put a nut inside of there that could break loose that you can't get to, instead of just threading the bolt directly into it.
So am I going to have to remove the entire sway bar including the corner frame piece where the sway bar bracket bolts on to the frame, get a new sway bar, corner frame piece and bracket? What a PITA!
Any ideas???
