coil specs out of range?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-04-2009, 09:58 AM   #1 (permalink)
mcx
View mcx's Photo Gallery
i bought a low end ignition coil replacement[Standard/Trutech] and was checking its primary and secondary output...its a 91 2.0 3sfe...the book says primary should be 0.38-0.46ohms and the secondary 7.7-10.4 k/ohms...anyway,this new coil is reading 1.5 ohms[primary] and 10.65[secondary]...is the high reading on the primary going to damage anything?? thx,mike
mcx is online now   Reply With Quote
Old 05-04-2009, 10:19 AM   #2 (permalink)
View 1883atlantics's Photo Gallery
if i were you i'd return it. if this ends up being the "gremlin" later on, you don't want to second-guess yourself. I dont know the specs for the 4banger offhand but you were smart to test it first.
jeff
90 Le sedan AT, FWD
2vz-fe
1883atlantics is offline   Reply With Quote
Old 05-04-2009, 02:17 PM   #3 (permalink)
mcx
yeah...i'll return it....i opened up the distributor to check the original coil on the engine...its primary side reads 0.6 ohm and the secondary reads 9.08 k/ohms...primary is slightly out of range but the secondary is right in the middle...any input is appreciated...thx,mike
Old 05-05-2009, 08:50 AM   #4 (permalink)
mcx
i called Rockauto about the coil being defective and they gave a full refund..they dont want it returned,probably because they dont want to pay for the shipping....i'd recommend staying away from the lower end products as they carry quite a range to choose.
