I'm hoping a Toyota guru can help me out. I have a 87 Camry 4cyl auto with 130K. It has a new timing belt and distributor as well.
It ran fantastic for over a year after purchasing, but for the last few months I've been fighting an intermittent stalling issue.
From research here, I've tried the following;
Replaced cap, rotor, wires & plugs - no help
Replaced Coil - no help
Wired in the starter relay by pass - no help.
I'm moving from a house to a condo soon, and need to get it corrected. Plus, its dangerous to drive as it will stall at any speed or time. 90% of the time it will start again immediately, but there is a good 10% when you have to wait for 5 minutes or more.
Unfortunately I don't have any way to run codes, and I'm not very good with an ohm meter either.
Thanks in advance, and I look forward to your answers.
