Tell me what this is (video) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-06-2009, 03:07 PM   #1 (permalink)
View z44ss's Photo Gallery
What is the ticking? lifter, or something worse?
[IMG][/IMG]
z44ss is offline   Reply With Quote
Old 05-06-2009, 06:51 PM   #2 (permalink)
日産自動車パワー!
JMSports's Avatar
View JMSports's Photo Gallery
Maybe the oil isn't reaching the top of the head? A little tick is alright, but thats an extreme one in your case.
You should pull the bolts out of the top of the case and see if any of the lifters are hitting the top of the spark plug. That could also be an issue if the wrong spark plugs were used.
マイクジョンソン.___________________私は日産マキシマ自身ビッチ!
JMSports is offline   Reply With Quote
Old 05-06-2009, 09:35 PM   #3 (permalink)
Gameroom cash: $202300
View zppeacock's Photo Gallery
maby adjust valves? is there oil in it?
zppeacock is offline   Reply With Quote
Old 05-07-2009, 12:27 AM   #4 (permalink)
full of oil. the last owner said when it started he had an oil leak and didnt drive it much cause he had another car. but needed it one day and drove it without checking oil. he got on it hard to get past someone in front of him and thats when it started knocking. got home and checked the oil and it was dry. the seals have been fixed that caused the leak but hasnt been driven much since then. it only knocks on first start up, and then when its given some gas in the upper rpms. does not knock at idle or low rpms.
Old 05-07-2009, 04:22 AM   #5 (permalink)
DC 2vzfe dx's Avatar
View DC 2vzfe dx's Photo Gallery
i dont like the sound of that ticking noise!!! sounds major internal knocking
I LOVE MY 91 CAMRY 2VZFE!!!!
DC 2vzfe dx is offline   Reply With Quote
Old 05-09-2009, 08:09 PM   #6 (permalink)
View Shifterx's Photo Gallery
ouch
don't run it anymore
either pull the oil pan or the head,
but it sounds like it might be a crank problem
person i bought my camry from ran it with no oil,
and a bearing got fused to the crank
Shifterx is offline   Reply With Quote
Old 05-10-2009, 12:27 AM   #7 (permalink)
mmm... i actually bought the car for next to nothing to get my brother by while he gets his car fixed. i was hoping it was just a lifter, rocker or something like that. if its internal i think ill just let him run it till it dies and part it out when it does.
Old 05-10-2009, 01:49 AM   #8 (permalink)
6 TOYOTA's in stock
TVISMR2's Avatar
View TVISMR2's Photo Gallery
ding ding ding!
Rod knock much?
1992 TOYOTA MR2 - 180k miles * 2003 TOYOTA MR2 Spyder - 87k miles * 2006 SUZUKI SV650s
2002 TOYOTA Highlander 4wd Limited V6 - 25k miles * 1985 TOYOTA CAMRY DX - 130k miles *
1987 HONDA Elite 250
Hers ~ 1988 TOYOTA MR2 Supercharged - 87k miles * 1999 TOYOTA TACOMA - 125k miles
TVISMR2 is offline   Reply With Quote
Old 05-10-2009, 03:51 AM   #9 (permalink)
guess ill be getting rid or parting it out soon.
Old 05-10-2009, 10:36 AM   #10 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Exhaust manifold or catalytic converter shield, catalytic converter, exhaust gasket leak worn out cam bearings [non-replaceable] or rod knock.
Make listening device using long 3/16 rod and oiler and listen to the block below freze plugs ; if noise is loudest there,
put 20w50 oil in it and see if that will help to lessen the noise.
My engine knocks like this 2 seconds after starting, so I using pep boys 20w50 all the times it is cheaper then engine
Doctor J is offline   Reply With Quote
Old 05-10-2009, 12:58 PM   #11 (permalink)
it makes that knock after starting and then it goes away. then a different knock when you push the gas and raise the rpms
Old 05-10-2009, 02:26 PM   #12 (permalink)
Doctor J's Avatar
Drain the oil and look for metal shavings.
My friend however, had very quiet v-6 2.5, but drained oil revealed a lot of metal powder [one time he let the oil level to get too low].
Unplug injectors one at the time until noise wil lessen at one particular cylinder; if so, the big end rod bearing has problem in that cylinder
