1987 Camry valve train noise! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-08-2009, 01:54 PM   #1 (permalink)
View draker's Photo Gallery
So I just got finish doing the head gasket on my Camry. I put it all back together and lined up all the timing marks when putting the new timing belt. I turned the engine 720 verify there was no binding and that the timing marks lined back up which they did. I got it all back together and fired it up, then checked the timing with a light. It's where it suppose to be timing wise with it set to base time. However, once it warms up there is a lot of valve train noise. It wasn't like this before the job, so where could I have went wrong?
I didn't put a set screw in the exhaust cam split gear, but I didn't see it move. I don't even know what the purpose of this dual gear setup. Could this be the cause? I am going to tear it back down to verify the timing marks.. so my question is what else should I be looking for?
Before I put it back together I verified cams are in time[2 dots on gears are lined up to each other], crank at TDC, and cam timing pulley set on the mark)
What do you think?
Thanks!
draker is offline   Reply With Quote
Old 05-09-2009, 01:29 AM   #2 (permalink)
I figured out what the split gear is for.. got it all fixed. Thanks anyway!
Old 05-09-2009, 01:42 AM   #3 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
So why was it making the noise?
Jimnist is offline   Reply With Quote
Old 05-09-2009, 12:09 PM   #4 (permalink)
Because the split gear that is on the exhaust cam has a spring inside that needs to be "wound up" so that it puts tension on the intake cam gear. The instructions clearly state to set it before installing it, which I didn't do before because I didn't see it move when I took it off.
I guess it pays off to follow the instructions.
Old 05-09-2009, 01:01 PM   #5 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
he was hearing gear clatter
