1984 camry le shifting prob - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-08-2009, 10:53 PM   #1 (permalink)
View bigdstoy94's Photo Gallery
i have a 1984 camry le revese will only work when cold any help?
bigdstoy94 is offline   Reply With Quote
Old 05-09-2009, 06:17 AM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
The most common cause of no reverse is the failure of overdrive direct clutch.[C0]
to fix it you need to remove the side cover; there is procedure to verify this problem, by installing O/D sprag backwards and then checking if reverse come back.
If so the clutch plates need to be changed.
Another problem is failure of transmission direct clutch, especially if it goes to the third gear at 4000 rpm.This problem calls for complete removal and overhaul.
Doctor J is offline   Reply With Quote
