Originally Posted by Jimnist
Try to find where it's leaking from by going under the car or turning the wheels full lock to lock with the tyres on the ground(greatest strain on system) and look for leaks/drips on the ground. Because you said the return line is moving about, i would assume it might be a flexible hose somewhere along the return line that's cracked. Although i only think this because you say you're loosing fluid and not loosing heaps of fluid.
If it were the high pressure hose, you'd loose almost all fluid when there's high stress on the system.
actually, before i used the engine oil to slow down the leaking, a full reservoir wouldn't last more than a day. even when parked overnight, it would be empty by morning. i've peered at the undercarriage many times to try to find where the leak is coming from, but from the day i bought the car, it was all muck under there. i had planned to get two cans of degreaser and go to town, just haven't gotten to that bridge yet, and locating the source of leaking fluids in an engine bay can be a tricky thing to locate if the engine isnt clean enuff for u to distinguish a trail. my feed line is crystalised basically. it's on my list to change. but i'm gonna replace the rack, cuz i believe it's goin bad. i can hear noises from it when it's moved lock to lock
