After Market Window Switch Mayhem
1989 4-Cylinder Manual Camry Wagon
I have had my power window switches fail two times in the past...each time replaced with a junk yard switch. Now the passenger window switch has failed, and this time I thought I would rewire and use an after market switch. In the process I screwed something up. Now none of the window switches work, nor the power locks, nor the blower fans for heat, vent, a/c, etc.
I have checked all the fuses, in the three fuse panels I know of (under the hood, driver and passenger kick panels.) I guess it is a relay or several. Any suggestions? Coming up on summer with no way to cool off, and need a solution. Thanks!
edit: The fans are now working, maybe I bumped something back into place.
