Power Steering Rack Boot - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-14-2009, 07:49 PM   #1 (permalink)
View amdspitfire's Photo Gallery
I have a 1991 Camry and the steering rack boot has completely ripped. Is this what's causing my clunk sound when I'm driving over big bumps?
Should I just buy a new boot and replace?
amdspitfire is offline   Reply With Quote
Old 05-14-2009, 08:39 PM   #2 (permalink)
日産自動車パワー!
JMSports's Avatar
View JMSports's Photo Gallery
Yes, it should clunk when you turn corners as well.
Looks like this:
マイクジョンソン.___________________私は日産マキシマ自身ビッチ!
JMSports is offline   Reply With Quote
Old 05-15-2009, 12:24 AM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
The clunk could be the strut tops, ball joints or control arm bushings. It is unlikely that it is the swaybar.
You can easily replace the steering rack boots (ask for a "steering gear bellow" at the auto parts store), but you will need a front-end alignment afterwards.
-Charlie
Old 05-15-2009, 09:16 AM   #4 (permalink)
日産自動車パワー!
JMSports's Avatar
-Charlie
I think i need an alignment anyway. Ever since i noticed the broken boot, the car has been heading to the right when i dont touch the wheel, and normally it used to head a bit to the left.
Old 05-15-2009, 12:31 PM   #5 (permalink)
white90dx's Avatar
The original poster is talking about is steering rack boot, not CV joint boot... different issues...
Either one should be fixed though.
-Charlie
Old 05-15-2009, 03:03 PM   #6 (permalink)
日産自動車パワー!
JMSports's Avatar
Oh, wow im slow didnt even realize i hijacked his thread. thought he had the same problem as me, so i could share in his agony
Definitley both need to be fixed though.
Old 05-16-2009, 11:18 PM   #7 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
If the boot on the steering rack has been deteriorating for some time, it may have caused problems with the inner tie-rod. Make sure to check this before you slap a boot on and call it good. If it's allowed to go too far, it can cause catastrophic problems just as a blown outer tie-rod end can...
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 06-04-2009, 11:31 AM   #8 (permalink)
I replaced the boot, and emptied 1 bag of wheel bearing lube inside of it. The outter tie rod when i wiggle it by hand leaks a little on the inside of the boot. The inner tie rod I didn't even know about so I didn't really examine.
The clunking sound was a little better for a day or so, now it's back to normal. Bushings look ok, what else can I check? Should i remove the whole strut?
Old 06-04-2009, 01:00 PM   #9 (permalink)
white90dx's Avatar
Steering rack boots should remain dry. If there is leaking fluid from the rack, you need to fix that. The grease that you added in there should be removed and a new boot put on there. Make sure you get an alignment done after you replace the boots - a cheap 'toe and go' should be fine.
-Charlie
Old 06-05-2009, 05:08 PM   #10 (permalink)
-Charlie
stupid a&& kragen! I think the boot is leaking from that joint, is this the source of sound that I am getting?
