90 Camry headlights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-15-2009, 11:34 AM   #1 (permalink)
View Daddygonz's Photo Gallery
90 Camry headlights
Does anybody make a aftermarket headlight for Gen 2 (1990) Camry? I do alot of headlight retros and I need a set of Clear lenses headlight for my HID projector project. Or a site where I can get a set of real JDM headlights(new or used) with the built in fogs?
THANKS IN ADVANCE
04 G35 coupe, 04 Roush Focus, 02 I35 sport, 94 S-10 PU, 91 Golf 16v, 90 Camry, 86 300ZXT.
Daddygonz is offline   Reply With Quote
Old 05-15-2009, 01:09 PM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
I appreciate you are trying to do it the right way! A few of us in here spend a fair amount of time working to convince people that re-based bulbs in the stock housing are a bad idea. I assume you are also on HIDplanet?
Sadly though, there are no aftermarket headlights for the gen2 Camry that anybody here has found.
JDM and Austrailian lights have the extra inner bulb, but they are actually driving lights with a spot pattern and lots of glare. They are great as supliments to the high beams, but not around town. I don't know of a good source for them - I got mine used from another board member. You need the matching corner lights, grill and nose piece of you want to do the conversion.
-Charlie
Old 05-15-2009, 01:16 PM   #3 (permalink)
white90dx's Avatar
You probably want the JDM headlights and the bumper, right?
I can't wait to get the bumper painted and put on... I also have a Euro factory lip spoiler and carbon fiber hood that will be going on the car.
-Charlie
Old 05-15-2009, 05:41 PM   #4 (permalink)
View 1883atlantics's Photo Gallery
THANKS IN ADVANCE
Pull off a "real" HID projector retrofit on a Gen2 and I think you'd be a legend on this board.
Just out of curiosity, what projectors did you find to fit in there?
Jeff
90 Le sedan AT, FWD
2vz-fe
1883atlantics is offline   Reply With Quote
Old 05-15-2009, 11:08 PM   #5 (permalink)
日産自動車パワー!
JMSports's Avatar
View JMSports's Photo Gallery
Jeff
90 Le sedan AT, FWD
2vz-fe
Pull it off, and ill be buying the first set from you.
マイクジョンソン.___________________私は日産マキシマ自身ビッチ!
JMSports is offline   Reply With Quote
Old 05-16-2009, 12:34 AM   #6 (permalink)
At the moment I have an extra set of FX35 Bi-xenon projectors. My first retro job was 350Z projectors on my 86 300ZX turbo. Next was a TSX projector on my daughter's 95 Camry until she totaled it last June. my resent project is FX 35 projectors on my 91 Golf with 7" rounds. My son is working on Dual Bi-xenon projectors on his 04 G35 coupe. If I could just find some clear lense lights I would be golden. I might just measure our headlights and see if I can find some other model car with the same or close to the same size. Modifying bracket on the inside is simple or I can fabricate some with fiberglass just like I did on my 300zx.
Here is my Z with lights on
[IMG][/IMG]
And he is my Golf set-up
[IMG][/IMG]
Jeff
90 Le sedan AT, FWD
2vz-fe
Old 05-16-2009, 01:31 AM   #7 (permalink)
View nuron's Photo Gallery
Pictures don't work! A HID retrofit would be a tremendous upgrade over the puny 9004 bulbs!
nuron is offline   Reply With Quote
Old 05-16-2009, 09:11 AM   #8 (permalink)
日産自動車パワー!
JMSports's Avatar
Pics work. You could have a glassmaker crack an original housing open and take measurements and reproduce a lens. Call an aftermarket housing specialist. They may be able to reproduce a lens like they would normally by changing the molds.
Old 05-16-2009, 10:46 AM   #9 (permalink)
Did you have to deline the Golf headlights?
Old 05-16-2009, 12:38 PM   #10 (permalink)
View Wangan's Photo Gallery
Have some faith people. A few years ago I brought forth a group buy on a Gen 2 specific coilover kit. I'm currently working on setting that up for possibly a clear glass replacement for our headlights.
http://i4.photobucket.com/albums/y11...3385Medium.jpg
Here's my camry ^
Current: B+G Springs, KYB GR2 Struts, Erebuni Bodykit(uninstalled), 3SGTE/E52 swap, Crane HI-6S Ignition Box, Crane Timing Retard Controller.
Plans: Here
Wangan is offline   Reply With Quote
Old 05-16-2009, 07:38 PM   #11 (permalink)
AUSFAG's Avatar
View AUSFAG's Photo Gallery
I've always wanted to know if there were projector lights for the gen2.
Even getting a set for another car and retrofit them into the existing headlights.
Just had a quick look on ebay, found a few that could possibly work out with a bit of handy work.
http://cgi.ebay.com.au/Twin-Halo-Pro...3%3A1|294%3A50
http://cgi.ebay.com.au/METAL-PROJECT...3%3A1|294%3A50
^^ that one would be the easiest to fit as they are just the projectors.
AUSFAG is offline   Reply With Quote
Old 05-16-2009, 09:14 PM   #12 (permalink)
Retrofitting is useless without a clear lens for the beam to go through. I wouldn't use those eBay projectors either, as OEM projectors from the TSX, S2000, etc. are way better and popular.
Old 05-17-2009, 12:18 AM   #13 (permalink)
the headlights on the golf are FK clears. The lens are clear glass and the inner lights are clear high beams.
Old 05-17-2009, 02:07 AM   #14 (permalink)
View Jeoy Gunz`'s Photo Gallery
there is a guy on cardomain who put headlights from a e36. he said there wasnt much modifying just had to add some brackets. I plan of doing this once my classes are done. This is the set im gunna get.
http://www.amazon.com/92-98-Projecto...2543993&sr=8-3
Jeoy Gunz` is offline   Reply With Quote
Old 05-17-2009, 03:06 AM   #15 (permalink)
Nice, do you have a link to the cardomain profile?
