Originally Posted by Doctor J
Camry has 2 speed sensors one inthe tranny ,one in the cluster;if you are suspecting tranny sensor check the wiring first.
Wrecking yard can be a good place to try
I tested the sensor. It failed the continuity test and no pulse when a magnet is passed by it. I have another 90 Camry I've been robbing parts off of. I took the tranny speed sensor off of it and it tests the same. I haven't been able to find out what the resistance is suppose to be. I took the instrument cluster out and checked the speed sensor in there and it is working.
