Downshift problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-25-2009, 12:32 AM   #1 (permalink)
stanno's Avatar
Gameroom cash: $103635
View stanno's Photo Gallery
Downshift problem
how do i know if it's th fault of the throttle cable or the a140e transmission ?
-stanno
stanno is offline   Reply With Quote
Old 05-25-2009, 02:46 AM   #2 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
Adjust the kickdown cable first
Jimnist is offline   Reply With Quote
Old 05-25-2009, 03:17 AM   #3 (permalink)
stanno's Avatar
is that done from the throttle body linkage ? should i adjust it to be almost tensioned ?
Old 05-25-2009, 03:29 AM   #4 (permalink)
セクシーの定義
Umm....not sure how it should be adjusted, but search around. I know there's write-up in the gen 3 section, and it should apply (maybe with some subtle differences).
Old 05-25-2009, 03:14 PM   #5 (permalink)
stanno's Avatar
didnt find it exactly but i somewhat adjusted the throttle cable and i think it's kicking down now. the gas pedal previously had some free play in it before the car would move and since i adjusted it it's now gone. i def see teh rpm go up sharply when i floor it from cruising speed
thanks for the reply
-stanno
Old 06-01-2009, 05:02 PM   #6 (permalink)
stanno's Avatar
quick question... would the tranny being overfilled with fluid have any effect? reason i asked is cuz i checked mine and the fluid is about 2" above the full mark ...
-stanno
Old 06-01-2009, 07:44 PM   #7 (permalink)
View nuron's Photo Gallery
Definitely, drain it to the appropriate mark.
nuron is offline   Reply With Quote
Old 06-01-2009, 09:26 PM   #8 (permalink)
Gameroom cash: $202300
View zppeacock's Photo Gallery
-stanno
Yes, I had the same problem, I drained the tranny and refilled it to the correct level and it works awesome.
zppeacock is offline   Reply With Quote
Old 06-02-2009, 01:32 PM   #9 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Make sure you check the level using the appropriate methods...
When cold, use the "cold" marks (engine off). When hot (after driving 6+ miles), use the hot marks - park on a level surface with the engine running, cycle through every gear and back to park then check the level with the engine running.
My auto was about 1/2 quart to high and it caused downshifting problems (when coming to a stop from speed).
-Charlie
Old 06-02-2009, 02:48 PM   #10 (permalink)
stanno's Avatar
-Charlie
So ure saying that upon deceleration, the car should start downshifting prior to stopping ? i didnt even kno that, mine doesnt do it at all. it just coasts to a stop with brake alone
Old 06-03-2009, 01:11 PM   #11 (permalink)
white90dx's Avatar
Watch carefully - you will see the RPMs jump up a couple times (from maybe 900rpm to 1100rpm) when coming to a stop. Its not any sort of performance downshifting or anything - just keeping the motor from stalling. When it was happening to my Alltrac, the car stayed in 2nd gear all the way to a stop, which stalls the motor.
-Charlie
Old 06-08-2009, 09:40 AM   #12 (permalink)
stanno's Avatar
-Charlie
i got the chance yesterday to give the car a proper and distant road testing. i found the car only downshifts from coasting if i'm doing so at a very low speed. if i'm coasting at a higher speed and i go wot, there's no downshift, i just hear the engine trying to build up speed.
