What to replace ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-02-2009, 03:58 PM   #1 (permalink)
stanno's Avatar
Gameroom cash: $103635
View stanno's Photo Gallery
What to replace ?
The last time i carried out a plug change, i saw that the threaded section of one of the spark plugs was wet with motor oil... tho the actual tip was not. The car doesnt smoke any at all, so i doubt it's valve seals, maybe it's a worn valve guide ??
stanno is offline   Reply With Quote
Old 06-02-2009, 09:08 PM   #2 (permalink)
View nuron's Photo Gallery
Tighten your spark plug seals (on the valve cover where the spark plugs go into).
nuron is offline   Reply With Quote
Old 06-03-2009, 01:02 AM   #3 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
Will this always work? I;ve noticed there's a bit of oil in cylinder 4, so i guess i'll try that before putting new seals in. If it tighten it, will i have any trouble removing it in the future?
Jimnist is offline   Reply With Quote
Old 06-03-2009, 02:01 AM   #4 (permalink)
That's the solution that I often see for this problem. The tube seal is like a nut so unless you strip it or use the hand of God to tighten it, there shouldn't be any trouble removing it later on.
Old 06-03-2009, 05:28 AM   #5 (permalink)
セクシーの定義
Would it be possible for the tube to tighten instead (crushing steel tube further into aluminium head) of the nut or when removing, start unscrewing the tube instead of the hex nut?
Old 06-03-2009, 07:57 AM   #6 (permalink)
The actual tube itself can only be fully seen with the valve cover off. So, the only way is to srew the hex nut when you remove. You can try tightening the nut first and see if it helps. If it doesn't it'll probably be the tube that's the culprit...Mine has the same problem, I haven't gone back to check yet but I'll have to do that soon.
Old 06-03-2009, 09:04 AM   #7 (permalink)
stanno's Avatar
well i'm goin to try tightening the hex nut first, altho the car is a 1990 model, it's probly due for some seal replacement, donno when last the past owners did this if any at all.
