I guess it was inevitable that I'd do a 3S-GTE swap. Plans for the swap are going smoothly, except the one part I'm stuck at: Mating the 3S-GTE to the transmission.
One option is to keep the S51 transmission, which requires a custom clutch using the S51 splines and the 3S-GTE flywheel/plate. Has anyone actually gone this route, and if so, where'd you get the clutch made? I went to advancedclutch.com, but they want detailed specifications and dimensions that I don't have. Telling them "S51 splines and 3S-GTE flywheel" isn't enough I guess. I assume that putting the S51 clutch into the 3S-GTE flywheel/pressure plate wouldn't work.
The other option is using the E52 transmission from a V6 Camry. Seems easy enough since the V6 axles would fit the hubs ok, and I could use the stock 3S-GTE clutch, but I'm stumped on what to do with the halfshaft. I don't think the halfshaft from a V6 will bolt on the 3S block, and I don't think the S51 halfshaft would simply plug into the E52 (Could be wrong?).
Most 3S-GTE swaps seem to end up using an E series tranny, so what would work in this situation? Is the MR2 turbo axle bearing bracket + E52 halfshaft the only solution?
This project is on a budget, so nothing fancy like an E153 because I know someone's going to say it.
Thanks
btw - It's an ST185 3S-GTE
