new transmission, new problem!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2009, 10:19 PM   #1 (permalink)
View JDM_KING's Photo Gallery
okay guys, the car is 1992 toyota camry LE 4cly, recently my old trans took a dump so i replaced with a used one from the yard, everything went well, got everything together and the car wouldn't start! put the car in drive to let it roll down teh drive way, for some odd reason the flywheel/torque converter doesnt spin, starter gets very HOT. is something seized? dhelp me out guys
JDM_KING is offline   Reply With Quote
Old 06-19-2009, 08:30 AM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
If starter hums and getting hot, disconnect the battery and try to rotate engine clockwise at the crank bolt. If engine does not spin, the tranny should come out to verify that torque converter cut-outs are properly engaged with front pump drive.
If you were removing the flexplate check the spacers on the crank flange.[if switched around, the TC will be pushed to the pump drive preventing it from rotation].
Doctor J is offline   Reply With Quote
Old 06-19-2009, 10:44 AM   #3 (permalink)
日産自動車パワー!
JMSports's Avatar
View JMSports's Photo Gallery
And just so you know, this is the wrong Section for you. You have a 92 Camry so your better off posting in the corresponding section. (Gen 3)
This section is for Gen 1 and Gen 2 Camrys. Although we still like to help here!
マイクジョンソン.___________________私は日産マキシマ自身ビッチ!
JMSports is offline   Reply With Quote
Old 06-19-2009, 09:50 PM   #4 (permalink)
i noticed that when i finished posting it, sorry if in the wrong section mods please move this!
Old 06-19-2009, 09:52 PM   #5 (permalink)
okay, converter cut-outs, flexplates? what spacers and where? this is my first auto trans replacement, i've done many manual honda trans replacement but never a camry, thanks for the help, i'll try and rotate the engine tomorrow.
Old 06-20-2009, 08:12 AM   #6 (permalink)
Doctor J's Avatar
the spacesrs located on the crankshaft flange;they usually put like this:
spacer-flexplate-spacer- bolts or flexplate-spacer-bolts without spacer between the flange and flexplate;
Old 06-20-2009, 11:02 AM   #7 (permalink)
those were not touched at all durning the whole process
Old 06-22-2009, 08:35 PM   #8 (permalink)
okay guys, motor does not turn by hand, i took off the trans, and there are two shafts, on big and one small on the trans, the bigger one goes over the smaller one, i tried turning the bigger geared shaft and it does not turn at all, i tried putting it in different gears but no go, the small shaft spins freely but the big one doesn't, does this mean the trans is shot?
Old 06-22-2009, 09:05 PM   #9 (permalink)
Doctor J's Avatar
The big splinned shaft is not supposed to turn [hence the name"stator shaft"]
you need to inspect the cutouts in the torque converter for damage and you also need to make sure the torque coverter cut outs are the same on old and new one.
Old 06-24-2009, 08:17 PM   #10 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
put the converter back onto the trans and turn it, be sure it drops all the way down
Old 07-08-2009, 12:30 AM   #11 (permalink)
torque converter was the one that came with the new trans. im thinking the flexplate shifted when i put the torque converter and trans on, so looks like i'll have to take it apart again! ccutouts looks to be fine
Old 07-08-2009, 08:42 AM   #12 (permalink)
Doctor J's Avatar
The number and size of spacers under the flexplate may be different between JDM and american market cars. it can be very good idea to check the distance between tranny mounting flange and torque converter to flexplate mounting pads using staight edge and ruller on old and replacement tranny.www.camrystuff.com , gen 3, , AUTOMATIC TRANSAXLE – ASSEMBLY REMOVAL AND INSTALLATION page
AX1–27; figure 2
"Using a scale and a straight edge, measure from the
installed surface to the front surface of the transaxle
housing.
Correct distance:
13.0 mm (0.51 in.) or more"
Old 07-10-2009, 12:06 AM   #13 (permalink)
AX1–27; figure 2
housing.
Correct distance:
im sure the motor is a usdm motor, i got the trans from the junker too. so im sure its a usdm trans as well.
Old 07-10-2009, 02:13 PM   #14 (permalink)
how do i go by installing those shims? or removing them? would i need all of them? can i just take them all out? help me out guys
