Just noted you having v-6
Refer to
www.camrystuff.com, go to generation 2 engine mechanical.
important !!!!!!
1)mark the belt relative to the cam and crank sprockets.
2)put direction arrow on the OLD belt
3) mark !!each!! cam sprocket relative to the #3 timing cover
4) line up old and new belts side by side straight; transfer marks and arrow from old to new belt[you may use books to keep the belts straight or have helper to hold them.
For water pump USE sealpacking black RTV sealant from Toyota it is very "forgiving" sealant for novice.
Use air, electrical or even cordless 1/2 inch drive impact gun to remove crank bolt; NEVER ever use chain wrench to hold the crank pulley
You may need to get new tensioner for the T-belt.
