Little power after timing belt/water pump change - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-25-2009, 04:52 AM   #1 (permalink)
View histriumph's Photo Gallery
2nd Generation Little power after timing belt/water pump change
I just replaced the water pump and timing belt on a 1991 Camry 3SFE automatic with 157K miles.
I got everything lined up and back together but now the car has little power. It starts,idles,and revs fine but when I take it down the road,it seems like a 2 cylinder instead of a 4. When the accelerator is pressed, power builds very slowly. Any thoughts? Thanks
histriumph is offline   Reply With Quote
Old 06-25-2009, 08:05 AM   #2 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
These threads are becoming more and more common. They always say everything is lined up and properly timed. But at the end of the day, your timing is off.
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline   Reply With Quote
Old 06-25-2009, 10:25 AM   #3 (permalink)
Timing
10-4 Jimnist.
Old 06-25-2009, 10:58 PM   #4 (permalink)
セクシーの定義
Also, make sure you jump connectors 'T' and 'E1' at the diagnosis connector when checking ignition timing and set it at 10* BTDC. It stops the ECU from advancing/retarding timing so you get a proper reading. After removing the jumper, timing should move between 14 and 19* BTDC at idle speed.
Camry history:
Old 06-26-2009, 10:04 AM   #5 (permalink)
Thanks Jimnist, Do you know the proper idle speed range for this engine?
I cranked it up when I screwed up the timing belt installation and it was idling low. Other than the high idle, she runs like a champ now.
Old 06-26-2009, 12:32 PM   #6 (permalink)
セクシーの定義
What's it idling at now? My manual says 700 +/- 50 rpm. Mine's idling at 1k with a warm engine (goes to 2k when cold), but i just can't be bothered lowering it, good enough lol.
Camry history:
Old 06-26-2009, 12:53 PM   #7 (permalink)
Justin727's Avatar
View Justin727's Photo Gallery
yes sir you're timing is off probably just a tooth too
2000 4Runner 3RZFE 5speed
PT70 Built Supra 600hp behind us now
1991 2vzfe Camry Le loaded
1995 Corolla DX sunroof (Totalled )
2004 TRD Tundra V8 (sold)
Justin727 is offline   Reply With Quote
