90 camry 4 3S-FE standard not starting, PLEASE HELP
how are you guys doing?
my camry has high milage, 270k pluss but still runs great when it starts, if it starts. if i push it down hill and pop it in 2nd, it will go. if i turn the key, all my accesories and dummy lights turn on , but no click. i thought it was the solenoid, but i tapped it and it didnt return the spring and still no crank so i replaced the starter. no crank, i hotwired it and still no crank so i doubt it is ignition even though the key shook and u could remove it while running (which is why i hotwired it and installed a push button start, which doesnt start it...) i gave my starter direct power from the battery and it turned but didnt engage...i read about the Neutral Start Switch on these cars, but the car still wont start if i juggle the shifter or press my clutch down on all different ways, just no go. the reverse lights do come on but im thinking since my car is manual and not automatic the NSS shouldnt be a problem. the car did this once and i push started it, drove it for 110 miles and it started again, then sat parked and now no go. i know my positive terminal is slightly corroded and i should try takin bakin soda to it and cleaning it, any other suggestions as to what might make it not start unless it is pushstarted? when it is running it runs just dandy, bt it does me no good unless i find hills to park on... thank you for your time
btw, i cant finish my push button start unless i get my starter to crank, i get all my dash lights to come on with a switch but the starter just wont go and I am not looking to buy a new ignition
