Brake pad too thick? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-10-2009, 07:43 PM   #1 (permalink)
View coolien35's Photo Gallery
91 camry 3SFE
I'm trying to replace the front brake pads and they seem too thick??? I can't the caliper back in place. I did compress the piston all the way back in. Still no go. I'm quite sure I got the right pads. Any suggestions ?
coolien35 is offline   Reply With Quote
Old 07-11-2009, 11:25 AM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
The total thickness of the pad is 15 mm including metal backing plate.
{10 mm linning 5 mm plate]
the piston should be almost flash with caliper surface; use "c" clamp to push piston in.
Doctor J is offline   Reply With Quote
Old 07-11-2009, 11:33 AM   #3 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Doctor J made a good point: make sure that the piston's outer surface is flush with the caliper bore--if it's not retracted 100% then the new pads might not quite clear. If you can't get the piston completely compressed then it may be seized.
BUT-and this has happened on both my Camry and my Celica-make sure the store gave you the right pads. Sometimes their computer "shows" a part number being appropriate when it's not.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 07-11-2009, 12:53 PM   #4 (permalink)
Thanks for the replies
The pads are indeed 15mm. The problem is not with the piston, I can't fit the caliper over the pads. Could it be that the sliding bushing is suppose to compress on the caliper (I've never done brakes before)? This is the only thing that is sticking out too much.
I know i'm not explaning this very well, i'll try to post pictures if I can.
Old 07-11-2009, 01:18 PM   #5 (permalink)
Gameroom cash: $302555
"Could it be that the sliding bushing is suppose to compress on the caliper "
Yes, the sliding bushings (there are 2 on each caliper mounting bracket) should move in and out with a bit of effort. Make sure they both move in and out freely; then try to push them back in to the caliper mounting bracket. Hopefully this will give you enough room to get the caliper back on.
In addition, check the new pads against the old pads and make sure they are identical.
Mike
Old 07-12-2009, 06:31 PM   #6 (permalink)
Sliding bushings were the problem. Tapped them lightly with a ruber mallet and everything went fine after that.
Thanks for the help
Old 07-14-2009, 12:12 AM   #7 (permalink)
Bullitprooph
*Groan* If the sliders are already sticking, slap a whole crap-load of anti-seize compound in the bore (either silver or copper will do). They're going to seize up completely by the time you get around to swapping the pads next time, and the inboard pads will wear-out roughly 50% faster than the outer pads...trouble, I tells ya.
Old 07-14-2009, 12:01 PM   #8 (permalink)
Doctor J's Avatar
Autozone used to sell caliper grease made for this purpose
