ok, when i bought my camry and did a thorough run through, i saw that the engine cross member's two rear bolts, washers & dampers were missing, so basically the rear of the crossmember rests on top of the suspension's cross member and causes some serious vibrations at idle and some play in the engine when accelerating from a stop. i went out to the dealer for 'em and they have none and haven't the slightest clue as to what diameter or size they are. can anyone say if i can simply remove one of the front bolts from the crossmember (at the lower radiator support area) and use that to match with another bolt at a local hardware or auto store?
here's a pic of the bolts i'm referring to:
