93 Camry - Water leak problems: what to do. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-18-2009, 02:05 PM   #1 (permalink)
View trelaine's Photo Gallery
Hi all,
I've a dilemma with a 93 Camry. I recently replaced the thermostat and belts -- unfortunately I didn't check the condition of this vehicle prior to doing the work. But it seems to be leaking in two places rather profusely when the thermostat opens.
I've posted images to give anyone a better idea of where it's leaking. You can view the image of the area affected here:
http://i144.photobucket.com/albums/r...cam-disc01.jpg
In this image I've marked three areas.
#1 - this looks like some kind of "weep hole" where it leaks when the thermostat is open.
#2 - Water is leaking from the bottom of this pulley shaft (or so it seems). I assume the water pump is here? I've checked to make sure that this isn't actually coming from someplace else like the thermostat or the pipe that connects to the thermostat housing.
#3 - I'm not entirely sure how to remove this bolt. I assume I put a screwdriver or something in one of the holes on this pulley to hold it in place before I remove it. BUT, do I need to remove this. I don't want to run into any surprises and make more work than I have to for myself.
I took a picture of the read end of the vehicle so you know what it is. It's posted here:
http://i144.photobucket.com/albums/r...cam-disc02.jpg
Any help would be appreciated.
Thanx much,
Tre
trelaine is offline   Reply With Quote
Old 07-18-2009, 02:12 PM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
You should post this in the gen3 section - you should be able to get more help there...
-Charlie
Old 07-18-2009, 02:22 PM   #3 (permalink)
Done! Thanks...
I wasn't sure what "generation" it was. Would be nice if the years were included along with the forum topic titles on the main list though.
Tre
