what the f@*#... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-19-2009, 11:05 AM   #1 (permalink)
3S Killa
Damea's Avatar
View Damea's Photo Gallery
what the f@*#...
well while i was sleeping someone used my car for 5 min and all my windows dont work..... from any of the switches..... my driverside power shoulder belt quit...... the key used to open all the power locks... that quit.... its been over 100 degrees and aint getting any better.... PLEASE HELP
blown fuse im guessing where to look first??? with work i dont have time to researh this subject or i would..... 12 hours a day for the next week.....
anyone
Damea is offline   Reply With Quote
Old 07-20-2009, 08:53 AM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
The circuit breaker for seat belt is affecting operation of BOTH belts, so the problem can be related to the common wire that goes into the driver's door.
Do these inspections:
a) Inspect this connector [left kick panel]
b) Check the ground wire in the driver's door;
don't leave car inattended!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Doctor J is offline   Reply With Quote
Old 07-20-2009, 02:19 PM   #3 (permalink)
3S Killa
Damea's Avatar
passenger side belt works when door is opened..... what the ground look like in the door.....
a fuse isnt the problem???
Old 07-20-2009, 02:53 PM   #4 (permalink)
Doctor J's Avatar
Take out the power window master switch unplug it and check for continuity between the body metal and the large white wire with black tracer;
then check for the 12 v at blue wire with ignition on.
Old 07-21-2009, 08:06 PM   #5 (permalink)
3S Killa
Damea's Avatar
2nd Generation
Volt/ohm meter here i come....... dont have one myself so ill get to it asap....
Old 07-24-2009, 08:39 PM   #6 (permalink)
3S Killa
Damea's Avatar
no power to any connections in the master power switch connector...... i get a ground signal on the blue wires and the light green ones.....in the picture in the left kick panel the only power i get is to the pink wire with green line.... electrical is not my thing........ i also noticed my sunroof was affected and with the windows fixed in the up position its not "cool".... couldnt i run a wire straight off the battery to the window motor as a quick fix???
PLEASE HURRY IM MELTINGGGGGGG.......
Old 07-25-2009, 02:15 PM   #7 (permalink)
Doctor J's Avatar
You will need to put (on)off(on) 15 A switch to control up and down window movement.
Old 07-25-2009, 04:02 PM   #8 (permalink)
3S Killa
Damea's Avatar
is this possible to do for all four windows.... or atleast the front two........ all on one switch..... or each on their own switch
also my shoulder belt is "stuck" in the open position..... i can deal with it being stuck.... only if it was in the closed position.... can i override it to get it closed some how......
with no power going to the switch at all..... and the wires all intact..... isnt it more than likley a fuse or relay that is causing my problem.....
if the seatbelt controller was affected some how wouldnt both belts quit working???
i would rather fix this than "patch it"..... but if i have to rig this up i will......
anyones opinion will be greatly appreticated
