CAI piping and Q's - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-03-2009, 03:20 AM   #1 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
CAI piping and Q's
Before i get flamed, i know this has been done to death. I have tried searching, but couldn't find my answer. Have seen it been brought up, but not answered.
1) I'm planning to make one very soon and was wondering, what would be a good size for the tubing? 2.5", 3" or other sizes?
2) So far, i've gathered that i'll need angled tubing (off throttle body and angled towards AFM), straight section and the 180* bend. How much of the straight section should i buy? Would 70cm be enough? Also, how far apart should the gap on the 180* bend piece need to be?
O--O
_ ^ That measurement approx? Excuse my bad drawing using keystrokes lol.
3) What is the diameter of the opening just before the throttlebody? 3"?
4) Where would be the best spot to put the bend (section between TB and AFM)? Right before the TB or around the middle of the section? I have a RHD, so i don't have to worry about the brake booster getting in the way. Does it even matter?
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline   Reply With Quote
Old 08-04-2009, 09:49 PM   #2 (permalink)
bumpnthump05's Avatar
View bumpnthump05's Photo Gallery
Intake I Bought And It Supplies Everything You Would Need.
http://cgi.ebay.com/ebaymotors/1987-1988-89-1990-1991-TOYOTA-CAMRY-2-0-RAM-AIR-INTAKE_W0QQcmdZViewItemQQ_trksidZp3286Q2ec0Q2em14Q QhashZitem5633a648e7QQitemZ370233723111QQptZMotors Q5fCarQ5fTruckQ5fPartsQ5fAccessories
This Is My Intake Setup
O--O
"Not Only Is It A Camry........ Its Faster Than You!!"
1991 Toyota Camry 2.0L 3S-FE (Future Tuner)
bumpnthump05 is offline   Reply With Quote
Old 08-05-2009, 12:39 AM   #3 (permalink)
セクシーの定義
Mine is currently an SRI (like that in the picture) with the stock piping, but want i to make a cold air intake (sucks air from fender well instead of engine bay).
I found out that the TB has an opening of 60mm and the rear of the AFM is 70mm. I see that the pipe doesn't change in diameter and the coupling are used as the reducers. Were they shaped to fit or did you have to stretch it?
Camry history:
Old 08-08-2009, 11:42 PM   #4 (permalink)
the gen 2
blkdmnrcing's Avatar
View blkdmnrcing's Photo Gallery
when i built my CAI, i used a section of 180 degree bend pipe that was 2.50 in diameter and ordered a premade section from JCWhitney. other then that i cant remember much, that was 3 years ago atleast
89 Camry I4 5-Speed - JDM Head, Turbo'd! Now needs Exhaust and Tune!!
93 Paseo I4 Automatic - Daily Driver
look out, ed wants to drop kick spiderman!!
blkdmnrcing is offline   Reply With Quote
Old 08-09-2009, 01:58 AM   #5 (permalink)
セクシーの定義
Did you have to go to a place that bent it for you? If so, how much did that roughly cost? Was this an exhaust shop or a pipe bending specialist?
I went to a steel shop the other day and they only had 3" (2" was the next size down) straight piping; no bends or reducers. So now i plan on going to a plumbing store to see if they have the pipes i require. I know they have the correct pipes, bends and reducers in HDPE, but not sure about copper.
Edit: Local auto shops are a complete rip-off for parts like these as they know people will pay for it.
Camry history:
Old 08-10-2009, 12:38 PM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
you wont gain 5 hp from this, you already have a cold air intake, all you really need to do is get a v6 air cleaner box and adapt your mass air to it, the motor has no problem on the intake side already, the problem is getting the air out
Old 08-11-2009, 01:13 AM   #7 (permalink)
the gen 2
i ordered it prebent from JCWhitney. it is 180 degree bend madrel steel exhaust piping.
