Ok,
So I'm driving the Gen2, which due to circumstances has seen better days.
While driving, I feel a shimmy on the front left wheel, then the car starts slowing down, then I smell burning, then the car eventually comes to grinding halt. During this time, I press the brake pedal and notice that it's harder than normal.
If I leave it alone for a couple of hours, I can drive it again for a while.
So I suspect it's a brake issue.
So this weekend, I check the front brakes.
Pads on left wheels look Ok, but I change them anyway. Rotor looks fine.
I turn hub to check for gridning, and there's none.
Ok, so I button that one up and go to right wheel.
Right wheel pads are more work because the caliper is frozen.
I pick up a replacement, put new pads, check rotor (it's Ok), and turn hub for nice smooth spin (no grinding). So I button that one up.
Bleed brakes, road test car around a couple of blocks, everything seems good.
Heading to work this morning, the problem has returned.
Although I've been here in TN for a long time, I don't know everything.
So instead of beating my head against the wall, I'd thought I throw this one on the table.
Anyone ever experienced this as I described above?
My gut says wheel bearing, but at this point I'm not sure.
I think the burning is coming from the front, then again, I can't be sure.
Right now I'm a little over-frustrated now to think clearly.
