If you're going to replace it, why not replace it with a good aftermarket headunit from Pioneer or something? It's pretty similar in terms of installing. All you will need is an additional wire harness to connect to the toyota plug and you can solder the other half of the Pioneer plug to it. Alternatively, you can get two harnesses Toyota > ISO(you cut this off if you want to solder/might not come with it - all depends on manufacturer) then ISO > Headunit brand. That is the most simplest plug and play option with zero soldering.
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
