coolant sensor??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-14-2009, 10:49 AM   #1 (permalink)
View bpe383's Photo Gallery
coolant sensor???
Under, and to the side a bit of dist. there is a block that has several coolant temp control items. Two being emissions, or BSVS and two appear to be coolant sensors. I purchased one of the coolant sensors that is mounted vert. closes to the nut that you lossen to adjust timing. There is another that is mounted horz., or facing me if I am standing in front of the car, on the same block. What is the proper name for this sensor so that I can have the auto parts guy look it up? We looked under coolant sensor but it only list the one I purchased already. Tried coolant switch, but that's not it either.
bpe383 is offline   Reply With Quote
Old 08-14-2009, 11:16 AM   #2 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
From my manual, there are 2 horizontal sensors; one being the EGR(exhaust gas recirculation) BVSV and the thermotime switch. I think you're referring to the latter
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline   Reply With Quote
Old 08-14-2009, 01:21 PM   #3 (permalink)
Thanks that would explain why I couldn't find the part.
Old 08-15-2009, 12:59 AM   #4 (permalink)
セクシーの定義
What's wrong with it? What does it do?
Camry history:
Old 08-15-2009, 01:06 PM   #5 (permalink)
the sensor is dry rotted and falling apart. still works, just planning on replacement ahead of time.
Old 08-16-2009, 12:50 AM   #6 (permalink)
stanno's Avatar
Gameroom cash: $103635
View stanno's Photo Gallery
I believe it's a timer for the cold start injector...
stanno is offline   Reply With Quote
Old 08-16-2009, 09:25 AM   #7 (permalink)
Gameroom cash: $302555
The timer for the cold start injector (called the cold start time switch) should be under a brown colored connector. The one that feeds temperature to the ECU should have a green colored connector.
Mike
