Originally Posted by Mike Gerber
That's means you are driving 10-12 miles a day for 30 days. Let's say you are going 300-400 miles in that month. If the level was full at the oil change and wouldn't register on the dipstick now, you have used at least 2 quarts of oil in those 300-400 miles. That is a tremendous amount of oil to be leaking. My guess is that "crossed threaded bung" is the main problem. Remember your oil is under pressure so that it can be pumped throughout the engine. I would check the oil level daily if you are going to continue driving this car, and get that crossed threaded bung retapped or replaced asap. Let's hope it's the bung and not the block threads that are ruined. After getting it fixed continue to monitor the oil consumption to determine if that was the main cause.
Also, with your climate and the oil loss, I would be adding 10W-40 or even 20W-50 oil until you get this leak problem solved.
Mike
Mike
Like clockwork... every morning before departure i check the level... this last time was the lowest i've ever seen it go... A mechanic friend of mine said i should come have him repair it this saturday... Pretty sure it's the bung cuz i cleaned the area & traced where the oil is seeping from... & also... when i tighten the bung (by hand)... i can feel it turn freely then it gets resistant ... then frees up again before finally goin all the way in...
... I forgot that the engine lubrication system is pressurized somewhat... so i'm now realising that the oil ... altho it may had looked like small amounts when parked... could've been squirting out like crazy while driving...
Appreciate the response Mike... i'll be sure to monitor it afterwards...
- Stanno
