The "max" pressure listed on the tire sidwall is the maximum RECOMMENDED cold inflation pressure. Meaning, it is safe to run that pressure any time.
You can run anywhere from the pressure listed on your door panel (anywhere from 28-32psi, depending on model, trim, engine, body type, etc) up to the max pressure of your tire, usually in the mid-40's.
I ran the 14's on my Alltrac around 40psi and got better gas mileage and better handling as a result. The ride was a bit harsher than at the recommended 30psi all around for the car.
-Charlie
