@DoctorJ
I found this thread:
compatibility of a A140L and a A140E
In it, you posted this:
No , the A140e will not work unless you install the electronic control unit, wiring harness and throttle position sensor with it. The A140L can work instead of A140e
Would you have any more details on approximately where these components are located in a Gen 3? Is the wiring harness connected from the Tranny ECU to the Tranny itself? Can you say what the TPS (Throttle Position Sensor) looks like? Is it possible to use the PWR/NORM button that the gen3 has?
@Atobe
not sure what you'd have to change... the E is electronic contoled while the L is mechanical controlled... could be as simple as getting the tranny + tranny ecu but i'm not really sure... the E was used all the way up to the 97 camry so it's easily found more than the L
There are definitely more gen3 camrys around here. The A140E would probably be a good upgrade.
Thanks to you both for contributing, it's got so quiet on this forum.
