Front signal lamp socket broke - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-29-2009, 05:22 PM   #1 (permalink)
View rossmore's Photo Gallery
Canada Front signal lamp socket broke
I have a 1991 Camry. When changing bulb on front right turn signal, original bulb broke as it had seized. Can't get bulb socket out. Used WD, Penetrating oil, and googone. Now trying to remove the lamp itself. How?
rossmore is offline   Reply With Quote
Old 08-30-2009, 11:23 AM   #2 (permalink)
Gameroom cash: $302555
Disconnect the battery and try a needle nose pliers to remove the broken bulb. Bend the base of the remaining bulb in to itself and then work it out. I would leave the socket alone if at all possible. Once the bulb is out, clean the socket with some sand paper and then use dielectric grease liberally in the socket before installing the new bulb.
Mike
Old 08-30-2009, 11:30 AM   #3 (permalink)
Correct bulb size
Finally got the bulb end out. Checked manual and it said 1156 which is clear with one filament. Checked the other side. Can't get that bulb out either but it's orange with 2 filaments. Is the manual wrong? Is there different 1156s for turn signals? Plus my husband said he can't get another bulb in as the pigtail is rusted. Any suggestions? And what bulb do I get at the store?
Help.
