Are you sure it's not suspension related? For instance, the control arm bushing, stabilizer bar bushing, ball joints, strut mount etc. My gen 2 makes clunking noises on the passenger side too sometimes when it goes over rough terrain & I'm pretty sure it's my ball joint worn on that side. But seeing as my car's a '90, i'm just replacing all the lower front suspension parts ie. bushings ball joints, tie rod end etc. I'd say visually inspect it first. You can usually spot worn and deteriorating bushings under there.
-stan
