power steering pressure hose leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-14-2009, 02:31 PM   #1 (permalink)
View DM89's Photo Gallery
i have an 89 camry 3SFE with a leaking high pressure hose. I'm looking for some advise on how to disconnect it from the pump. i can get a crowsfoot on the top bolt but it just spins the entire banjo fitting. What is the best way to hold the bottom nut so i can get the top bolt to unscrew?
DM89 is offline   Reply With Quote
Old 09-15-2009, 11:19 AM   #2 (permalink)
NVM.Just found some past posts on this issue that i overlooked earlier.
Old 09-25-2009, 06:42 PM   #3 (permalink)
View rookie206's Photo Gallery
DM89, Can you please post the link to that fixture? I am having the same issues. Thanks
rookie206 is offline   Reply With Quote
Old 09-29-2009, 11:26 AM   #4 (permalink)
search "power steering pressure hose" the first result will be this thread and the one below will be the one i looked at. You will need to have a dremel (and a lot of patience) to cut the old hose but you can do it without raising the car. you will also need compressed air or something else to blow away the chips from cutting the hose. hope this helps!
Old 09-30-2009, 12:36 PM   #5 (permalink)
mr.kenny's Avatar
View mr.kenny's Photo Gallery
I think many will agree that before attempting to remove this hose it would be suggested to consider pour copious amounts of flammable liquid into the interior and exterior of the vehicle and then throw a lit road flare into the open window. This will save you a lot of time and frustration in attempting to remove the hose and end up coming to the same conclusion as stated in the first suggestion...
(Oh, you have the 3sfe...piece of cake; weep for us owners of the 2vzfe)
mr.kenny is offline   Reply With Quote
Old 09-30-2009, 01:06 PM   #6 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
If you think its hard on a FWD Camry, you should try it on an Alltrac Camry... the transfer case sits right there below it - you have even less access that way.
-Charlie
Old 10-01-2009, 10:17 AM   #7 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
The above examples are of "design for assembly" vs. "design for maintenance ".
Doctor J is offline   Reply With Quote
