Does it run fine when cold, but starts missing once it's warmed-up?
Does it ever actually stall, or just stumble?
Does it do this in gear, in neutral, or both?
Did you replace the plug wires when you replaced the rotor and cap? Did you inspect the wires?
Give us a little more to go on and we should be able to throw some ideas at you. I recently had a similar problem and finally had to replace the plug wires--the squirrels had gotten in under the hood and were nibbling the coating off the wires on the rear bank (where I couldn't see them)...
 1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
