help! i cant figure this out!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2009, 06:58 PM   #1 (permalink)
bkbajan's Avatar
View bkbajan's Photo Gallery
im trying to figure out what would cause my engine to knock so badly,im scared to drive the car normally..the oil just got changed last week,new ram intake installed today,new plugs...any ideas?
bkbajan is offline   Reply With Quote
Old 10-01-2009, 08:08 PM   #2 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
Timing out? Are the ignition leads damaged? Was there any oil in the spark plug tube?
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline   Reply With Quote
Old 10-01-2009, 09:09 PM   #3 (permalink)
View clhdrums's Photo Gallery
not that this might help.. but what intake?
clhdrums is offline   Reply With Quote
Old 10-01-2009, 09:59 PM   #4 (permalink)
bkbajan's Avatar
its one from ebay..its a tight fit tho..the pipe's abgle is slightly off
Old 10-01-2009, 10:09 PM   #5 (permalink)
bkbajan's Avatar
how can i tell if the leads are bad?
didnt see any oil in the spark plug tube..but the plus were horrible,lord knows when they were changed!
could it be the tranny?
Old 10-01-2009, 10:37 PM   #6 (permalink)
try adjusting the rubber couplings so it goes roughly where you want it. I got the ChromIntakes one and had to do that.
as for the knocking? i would second the motion of checking your timing.
Old 10-01-2009, 10:46 PM   #7 (permalink)
bkbajan's Avatar
http://www.facebook.com/photo.php?pi...&id=1576377026
Old 10-01-2009, 10:50 PM   #8 (permalink)
bkbajan's Avatar
have u done this yourself? id prefer to do it myself..any tips on how to?
Old 10-01-2009, 10:51 PM   #9 (permalink)
yep. that looks like the chromeintakes intake. here's mine.
Old 10-01-2009, 11:01 PM   #10 (permalink)
just loosen the coupler rings (the things that tighten down the rubber couplings to the tube... i forget the official name) and bend the tube..just a little bit. in the direction you want it.. do this for every coupling and it'll be in the right direction
even though the directions say "don't adjust the rubber couplings unless you need to" .. i adjusted them.. because mine wouldn't fit because my battery.
Old 10-01-2009, 11:13 PM   #11 (permalink)
bkbajan's Avatar
ok,ill do tht 2moro.
i was asking about the timing..and if u had any tips on how to check/fix it
Old 10-01-2009, 11:25 PM   #12 (permalink)
http://camrystuff.com/index.php?page=Gen2_Manuals
1.go there
2. click on ignition
3. go to page IG-17
someone chime in if i'm off.
Old 10-01-2009, 11:45 PM   #13 (permalink)
bkbajan's Avatar
ok,got it! ill look into gettin the timing light..
Old 10-02-2009, 02:12 PM   #14 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Any chance the intake is hitting something? Check all the motor mounts too.
What kind of knocking is the sound? Is it internal or external? Have you checked your oil level?
-Charlie
Old 10-02-2009, 03:08 PM   #15 (permalink)
bkbajan's Avatar
-Charlie
the intake is fine,and the oil is spot on! how can i check the mounts?
the noise only comes under acceleration..on and off..
