My car stalls out in the rain. Help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-03-2009, 01:01 PM   #1 (permalink)
View DM89's Photo Gallery
I have an 89 Camry that stalls out in the rain. It will start up fine and drive perfectly until it warms up a little bit, enough to start blowing heat, at this point it will idle rough, stall when accelerating from a stop, and will barely start once it stalls. After it warms up to operating temperature it runs fine, usually for the rest of the day even if it sits for a while and cools off. I am leaning towards putting a new ignition coil, cap, plug wires, and distributor rotor on it since i haven't done that in the five years i've owned it and it is most likely causing the problem. But i don't want to just throw parts at it. does anyone know of anything else i should check first?
DM89 is offline   Reply With Quote
Old 10-03-2009, 10:24 PM   #2 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
Coil for sure if it stalls out when there's wet weather.
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline   Reply With Quote
Old 10-04-2009, 01:52 PM   #3 (permalink)
I forgot to mention that it hasn't set any codes. is that typical for a bad coil?
Old 10-04-2009, 08:59 PM   #4 (permalink)
セクシーの定義
I wouldn't rely on the ODB for everything. Take the dizzy apart and look at the coil, no doubt there will be a crack on it letting in moisture.
Camry history:
Old 10-04-2009, 09:09 PM   #5 (permalink)
Young Toyota Tech
View Turboman412's Photo Gallery
its an 89, its not going to set a code. replace the coil and you should be good
Turboman412 is offline   Reply With Quote
Old 10-22-2009, 08:10 AM   #6 (permalink)
so after waiting for the rain to stop in Michigan so i could change the coil then waiting for the rain to come back to see if i still had a problem, it looks like a new coil fixed it. I've driven around in the rain the last two days without a problem. The coil had no cracks that i could see but it was discolored in one spot. Thanks for the help Jimnist and Turboman412
