UPDATE: FIXED!.......FIXED!
CURE!{{Checked out each bulb one at a time; found one that wasn't making good ground evidenced by the discolored metal base.
It was the problem bulb...but it lit up fine.
The new bulb was the cure.}}
The dash warning light indicator for the rear taillights come on when stepping on brake pedal.... Only while headlight switch is on.
All the rear tail lights work & i have checked the connection of every bulb.
And I checked out the battery and alternator...both good.
Is there some sort of relay causing this?
