Power window master switch connector: wire location - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2009, 03:17 PM   #1 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
88 shown
The blue wire in the center is “hot” with ignition “on”
The white/blk wire below the blue one is the master ground wire.
If it is broken, all windows will be dead.
With all buttons on the switch in [off] position all green and all red wires are connected to the ground.
[ignore two thinner wires in the lower right corner]
With switch disconnected there suppose to be continuity between red and green wire in each corresponding pair [4 pairs total].
90 and 91 has 2 blue and 2 ground wires for redundancy
Doctor J is offline   Reply With Quote
Old 10-07-2009, 08:49 PM   #2 (permalink)
bkbajan's Avatar
View bkbajan's Photo Gallery
wht a friggin coincidence...im drivin today and my windows and power locks stopped working,yes..just like tht.
the main switch on the door doesnt even light up anymore..
wht kinda problem am i lookin at here,i need it fixed asap b4 te rain comes as one window is down and the others dont move at all...
ill check under the hood 2moro and try to look at the breakers.
how do i reset them?
thx
bkbajan is offline   Reply With Quote
Old 10-07-2009, 09:12 PM   #3 (permalink)
Doctor J's Avatar
pull the switch out with conncor plugged in
turn ignition on see if you have 12 v between the blue wire and good ground
if yes, attach the alligator wire from white/blk wire terminal to the good ground[like run another ground. If it works now repair the ground wire
If no power on blue wire locate circuit breaker inside left kick panel and reset it by pushing pin into the hole[there are 2 breakers next to each oth] ;the owner's manual should tell you which is which.
Old 10-07-2009, 09:20 PM   #4 (permalink)
bkbajan's Avatar
thx Doc,ill take a look 2moro
Old 10-08-2009, 08:53 AM   #5 (permalink)
bkbajan's Avatar
got it fixed,it was the beaker.
wht wud cause tht to happen tho?
Old 10-08-2009, 09:00 AM   #6 (permalink)
Doctor J's Avatar
dirt on the regulator,
rusted bearing on the motor
Old 10-11-2009, 04:08 PM   #7 (permalink)
flip67's Avatar
View flip67's Photo Gallery
Ok had the same problem and reset the breaker. That gave me back my door locks , my sun roof, power meres and the back passenger power window. But the rest of my windows wont work. I tested for ground. Ground is good. I tested for power. Power is good. I tested for continuity on all of the green and red wires and nothing. This is driving me nuts please help. 88 Camry all trac le
flip67 is offline   Reply With Quote
Old 10-11-2009, 11:03 PM   #8 (permalink)
Doctor J's Avatar
Are the windows working from their "local switches" [beside master switch]?
Old 10-14-2009, 02:32 PM   #9 (permalink)
flip67's Avatar
no there not
My baby 88 Camry All-Trac le
5 speed and loaded
Old 10-14-2009, 03:21 PM   #10 (permalink)
Doctor J's Avatar
Unplug the master switch ad try another one, if windows still do not no work,
check the wires between each door switches and for continuity master switch for wire color go to www.camrystuff.com, electrical wiring diagram power windows
The master switch in "neutral position" must have continuity between Master ground terminal and each of the 6 terminals of the green or red wires
