When installing the axle, the c-clip should be around the axle behind the bearing (between the bearing and the inner CV) sitting loose. Its been a while since I have done those axles, but I think you can even put the c-clip around the axle after it is in the car. The axle slides into the trans and the bearing into the bracket, then the c-clip is put into the bearing bracket.
I'm having trouble picturing where you are stuck...
-Charlie
