INSPECT RESISTANCE OF COLD START INJECTOR.</B>
- Disconnect the cold start injector connector.
- Using an ohmmeter, measure the resistance between the terminals.
Resistance: 2 - 4 ohms.</B>
If the resistance is not as specified, replace the injector.
- Reconnect the cold start injector connector.
OFF-VEHICLE INSPECTION
1.INSPECT INJECTION OF COLD START INJECTOR.</B> WARNING: Keep clear of sparks during the test.</B>
- Install SST (union) to the injector and delivery pipe with new gaskets and the union bolts. *SST 09268-41045
- Connect the unions with SST (hose). *SST 09268-41045
- Connect SST (wire) to the injector. *SST 09842-30050
- Put a container under the injector.
- Reconnect the battery negative (-) cable.
- Turn the ignition switch "ON".
NOTE: </B>Do not start the engine.
- Using a service wire, short terminals +B and FP of the check connector.
- Connect the test probes of the SST (wire) to the battery, and check that the fuel spray is as shown. *SST 09842-30050
CAUTION: Perform this within the shortest possible time</B> .2.INSPECT LEAKAGE.</B>
- In the condition above, disconnect the test probes of SST (wire) from the battery and check fuel leakage from the injector. *SST 09842-30050
Fuel drop: One drop or less per minutes</B>
- Disconnect the battery negative (-) cable.
- Remove SST and the service wire. *SST 09268-41045 and 09842-30050
