If you can get the two main lower strut bolts free and have the correct spring compressors, its not too hard.
The strut tops are reachable by removing the rear seat back and removing an access panel on each side. Don't try to remove the rear package shelf! The springs are under a lot of pre-load so take your time when compressing them. Make sure to get an alignment when you are finished.
Good luck!
-Charlie
