Well I'm replacing the ones on mine (clogged from debris - my fault hah)
And know a guy who has his set when he upgraded (he has a 3SGTE), was wondering if I could just swap mine with his?
I know they all share similar blocks, but I dunno about the fuel rail.
And about the control arm bolts, I thought they would be EXTREEMEELY tight, got out my 550ft/lb impact wrench (550 at 90psi, I ran it at 120), and cracked them... And then I threw them out the next day without noticing what they were
- bad memory.
Anyone know what bolt I should be looking for?
OBTW - Random question, I lost the wire connecting to the "Solenoid" (I'm guessing) on the starter, ground is connected to tranny, and the + wire is bolted onto the starter termianal - but the little clip slot above it has nothing, somebody told me I could just start it by putting a wire from the + terminal to inside the clip... any info? Can I do that just to turn it over and make sure the junkyard motor I bought actually turns over?
