Air Compressor help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2009, 12:24 AM   #1 (permalink)
Camry Lover
CamryFan1988's Avatar
View CamryFan1988's Photo Gallery
Air Compressor help
Hey fellow Gen 2 drivers
I have an 89 Camry 3S-FE with air conditioning that I picked up for a steal a few months ago. Once again its just the typical story of someone picking up a car and knew they had problems. I need to do some service work on the air compressor without disconnecting and releasing freeon into the atmosphere so I was just wondering if anyone has done this before and has advice/pictures/knowledge etc of the best way to get access to the compressor pully without disconnecting any of the hoses that carry the gas.
Thank you in advance.
Ride: 1989 Toyota Camry CS
W.I.P 88 Camry SE
CamryFan1988 is offline   Reply With Quote
Old 11-18-2009, 02:39 AM   #2 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
Don't think you can mate. You'll probably have to go to an auto leccy/air conditioning place and have them drain the system. If you're going to do that, may as well convert to 134a if it's isn't already so.
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline   Reply With Quote
Old 11-18-2009, 03:26 AM   #3 (permalink)
Camry Lover
It definitely isn't 134a and I was under the impression that it required a fair bit of extra pipes, cables etc to do a 134a conversion.
We've had it repaired at on another car before (the 88) and we believe we can see the scratch marks where they have tilted/twisted the compressor so I believe it should be possible to swap clutches without removing the compressor.
W.I.P 88 Camry SE
Old 07-06-2011, 07:29 PM   #4 (permalink)
View sleep_deprived129's Photo Gallery
You can do it, I found it easiest to remove the lower radiator hose and then you can remove the mounting bolts and get it out well enough to change the clutch/pulley. Ths hoses have rubber sections going to the compressor so there is some 'give' in them.
1970 Ford F-100 - 302, C4 Auto - First car, still goin strong!
1991 Toyota Camry - 3S-FE, Auto - First Toyota, Totalled
1980 Toyota Corolla Wagon - 3T-C, Auto - Sold
1988 Toyota Camry DLX - 3S-FE, 5-spd
sleep_deprived129 is offline   Reply With Quote
