'87 LE
226k miles.
Got it from the original owner.
Pretty in depth service history.
Got the car essentially for free. I did some minor paint/body work on another vehicle of theirs in trade. ($35 in supplies and about 6 hours of labor)
Replaced both side mirrors (came w/ black ones and driver side had been hacked w/ a repair)
Replaced broken passenger headlight assembly
Replaced broken driver side marker light.
Replaced RT rear molding.
Fixed loose connection in tail light.
Replaced misc bulbs here and there.
Replaced broken driver visor.
Swapped front signal lenses to clear
Power window's, locks and sunroof did not work. Found it to be a tripped circuit breaker. Reset it and now the locks and sunroof work flawlessly, but I'm having a few problems with the windows. Driver switch assembly will not control any of the windows. Applied power directly to the window motor, both ways jammed. (Need a new motor/regulator I presume). Passenger front window will roll down from it's switch
but not up. Both rear windows work fine.
Passenger auto seatbelt doesn't slide back after closing door.
Horribly bad oil leaks
Minor rust spots here and there.
Engine bay was crazy dirty with oil and grease
everywhere.
Trying to figure out where the oil is coming from here.
It's to the right and behind the exhaust manifold. It seems to be seeping from the top of the block somewhere.
There's also a gigantic oil leak on the firewall side of the motor that creates a puddle after the car is stopped. Will have to do some troubleshooting for that one. It's just the front one that gets me. Where the hell would it be coming from? I cleaned the whole area and can just follow it up to where the block an head meet, but can't see up in there.
