I've got some questions about installing a new radiator for the 4cyl on a 312k km engine as the old one has died(pinhole leak and it think causing my overheating problem)
1)Are the stock dimensions adequate for cooling?
2) What do i do about the oil cooler part? I've got a manual tranny. Just block/plug it off? Or fill with coolant or oil to stop corrosion?
3) What's the best way to flush the system? I read in an older thread that it's not good to flush the cooling system with 'straight' water because it can cause the waterpump to leak (due to thinner viscosity of water vs coolant).
4) What's a good ratio? I know 1:1 is the standard, but after reading the bottle, it only increases the boiling point by 5*C to 132*C (vs a 2:1 ratio of water-to-coolant w/ boiling pt at 127*C). Should i still go 1:1
Any help is appreciated
