Brake Bleeder? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-25-2009, 06:02 PM   #1 (permalink)
Gameroom cash: $121520
View karbonfyber's Photo Gallery
Brake Bleeder?
I am having trouble finding the nut that i need to loosen to bleed the left rear drum...I had no trouble finding it on the right one, but I can't seem to find one on the left drum. Does anyone have a photo or suggestion? 1990 Camry
karbonfyber is offline   Reply With Quote
Old 11-25-2009, 10:28 PM   #2 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
It's in basically the same location as the other side...if you can't find it, it may have been sheared-off at some point in the shady past. Have you removed the brake drum and inspected the cylinder from the inside?
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 11-25-2009, 11:13 PM   #3 (permalink)
Hmmm, I'm afraid it may have sheared off then. No, I haven't taken it apart yet, should I?
Old 11-26-2009, 08:08 AM   #4 (permalink)
Bullitprooph
The only reason I suggest removing the drum is that you never know with parts--there's a tiny chance that it's an aftermarket wheel cylinder with a different bleeder set-up. Probably not, but it can't hurt to be sure.
The good news, if it is shorn-off, is that these cylinders are dirt cheap to replace. And if you're bleeding the lines anyways then you're half-way there! Just be careful disconnecting the steel line from the cylinder bore--if you don't take care you can twist the line (especially if the fitting is rusted).
--Tim
